Salta al contenuto principale
Modello A1989, EMC 3358. Aggiornamento del modello esistente, con nuove opzioni per il processore e un cambiamento nei materiali della tastiera. Disponibile nei colori Argento e Grigio siderale. Rilasciato nel maggio 2019.
Randomly flickering display after display Swap
The Screen of my MacBook pro is acting strange. After I build in a new screen due to a Flexgate issue the new Screen is flickering randomly, specially if a lot of other devices are close to it. Here is a Video of the effect: https://youtu.be/TtT7Xo_nkLE
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Sadly, your video doesn’t show the problem. I’m suspecting that’s because you used the create video from the keyboard function which creates the video from the video feed instead of what you see from the screen directly.
So you need to use your phone or other device to create the video so we can see the issue.
At this point just based on your description and as you hadn’t captured the issue in this video I’m suspecting the replacement part is bad.
Punteggio 0
Aggiungi la tua risposta
Nasenbar Rt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 93
