Salta al contenuto principale
Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Why is only half of my lcd working on my mini 3 wi-fi?
The battery on my mini 3 needed to be replaced. I'm a novice but got the battery installed and checked before I closed everything up to see if it worked. The touchscreen works for the entire screen, but only half of the lcd works correctly. Did I flex the lcd too much when I removed it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi John,
Whenever you're working with big thin sheets of glass there's always the possibility of breaking something; it's one of the hazards of these kind of DIY repairs. However, in this case it doesn't look to me like a cracked LCD from being flexed during removal or installation.
My guess would be either possible damage to the LCD cable or the TAB connectors that connect the flex cable to the LCD glass, but it doesn't necessarily have to be that bad. I'd say the first thing you need to check is the display cable plugging into the LCD panel; those FPC connectors can sometimes be a little tricky to get in all the way so there's a possibility it's just not seated all the way and that's what you're seeing.
Of course, the problem is you're going to have to open the whole thing back up again in order to check it. Once you get there, unplug it then check both sides of the connector, both on the LCD and on the flex cable, looking for any bent, broken or missing pins; a magnifying glass and a bright light are recommended for that. Bent pins can sometimes be straightened with fine tip tweezers but broken or missing pins are a much bigger problem. Also check the length of the flex cable for any scratches or tears in it.
Assuming everything looks good up to now, clean both sides of the connectors with 90% or higher concentration of isopropyl (rubbing) alcohol. Let it dry, plug everything back in and retest.
If you still have problems then yeah, there's a good chance the LCD got damaged and needs to be replaced; that's really the only fix you can do in a case like that, since LCDs themselves can't be repaired.
So open 'er up and double check all the connectors that got unplugged when you did the battery then come on back and let us know what you found.
Punteggio 2
1 Commento:
Hi Jerry,
Thanks so much for taking the time with your answer. Fortunately, I had not put the mini pad back together and was able to double check your suggestions. I'd done that many times before and believe that my lcd connection is solid. The flex cable connection to the lcd glass itself also looks secure. I had also cleaned the lcd connection with the rubbing alcohol too.
So your comments confirmed what I already suspected: there is probably a problem with the lcd and/or cable and the only way to fix it is with a replacement. Thanks, that what I needed!
Also, I'm the one responsible for causing the problem. Live and learn. I liked working on computers that I could take apart easily. Computers with adhesive are a different animal and I'll never work on one again. Anybody want a new battery?
da
Aggiungi la tua risposta
John Leszar sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 15
Tutti i Tempi: 295
