Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2520 Domande Visualizza tutte
What voltage should be supplied to the battery when charging?
I have an iPhone 5 that won't turn on, and I'm trying to figure out why. It won't turn on with or without the battery connected.
When I run a multimeter over the connections to the battery on the logic board whilst charging, it varies between 1.2v and 1.3v. That's pretty low, and even after charging overnight (approx. 8 hrs) the battery did not hold a charge so I'm planning on replacing the dock connector and battery. Before I do that I just wanted to check, what should be the expected voltage being supplied to the battery?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
The lithium battery in the phone has a nominal voltage of 3.7 v. But that's an average. Depending on the % charge, the voltage can be between 3.2volts ( low charge) to 4.2 volts ( full charge). So I agree, your measurement of 1.2 v is very low.
I'd say you need a new battery, as you planned.
Punteggio 1
Aggiungi la tua risposta
hugh19s sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 21
