Salta al contenuto principale
Onn 10.1 Tablet Gen 3 2022 (100092980).
Having Trouble Getting a Piece of Screen From the Tablet
Hi, I am an 19-year-old guy that is trying to fix an Onn Tablet for my sister. I was doing a good job removing the screen from the tablet but for some reason it broke on of the sides off. I am trying to fix the tablet fully, but that one piece that is still on the tablet is not getting off.
So what do I do to get the thing off?? I do not have a heat gun or one of anything instead of a towel to remove the adhesive. So I’m in a panic right now, so what do I do??
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
The first step is to not panic it is a stressful situation, but it can be fixed with some patience. Now since you don't have a heat gun it's time to improvise use a hair dryer instead don't have one then get some isopropyl alcohol and soak a small piece of the towel and use the alcohol to break down the adhesive by simply dabbing it on the piece. If you do have a hair dryer, then make sure you have something to pry and pick at the remaining pieces of screen. Hope this helps best of luck!
Punteggio 1
1 Commento:
to add to this- be very careful if you're using a flathead screwdriver to pry it off! you could very easily damage the frame of the tablet, or even puncture the battery if you slip. @ghostjackplayz
da
Aggiungi la tua risposta
GhostJack Playz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 355
