Salta al contenuto principale
Fingering is disappeared in my settings
Fingerprint sensor is disappeared in my settings
Questa è una buona domanda?
Punteggio 3
6 Commenti
Fix a network problem
da
Infinix not 12 in no fingerprint work
da
Touch screen problam
da
da
Not work fingerprint
da
Mostra 1 altro commento
Aggiungi un commento
2 Risposte
Risposta Più Utile
Reconnect it
Punteggio 2
1 Commento:
@mroyceofficial how can that be done?
da
@raorajput update your software first. If it still does not show after you upgrade your software, it is possible that your fingerprint sensor has failed and thus your software can't find it. Check on here for the setup and on here for possible fixes. Different model, same idea. If none of this works, you may need to replace the sensor. Problem is that guides for this are not easily found
Punteggio 0
Aggiungi la tua risposta
Rao Rajput sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,047
