Salta al contenuto principale
The Kia Sportage is a compact crossover SUV (sport utility vehicle) manufactured by Kia Motors, a South Korean automaker, since 1993. Between 1993 and 2005, the Kia Sportage was classified as a compact SUV.
6 Domande Visualizza tutte
Door is not opening from outside
My kia sportage door is not opening from outside but it only opening from inside
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@zunairzahid you will need to remove your door panel and check the connecting rod to the outside handle. Either they popped out or the plastic handle broke,. If it is broke , you will have to replace the handle. If it just popped out, replace the rod and secure it.
If your are talking about your power door lock not unlocking it, the it is the lock actuator that needs replacing.
Punteggio 0
Aggiungi la tua risposta
Zunair Zahid sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 106
