Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
782 Domande Visualizza tutte
Why does my trackpad get stuck?
My trackpad is stuck due to dirt. The clicks don't work by pressing the trackpad but nevertheless it still works if i tap the trackpad.
I would like to know how i can clean it and would the warranty be off if i do it. Would genius charge me for the fix if i go to them? I live in the netherlands and we don't have any genius stores here.
Thank you.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The trackpad is easy to replace or adjust on this machine. You simply remove the battery to gain access to it. I would remove it and try using compressed air to clean it out.
Punteggio 3
Aggiungi la tua risposta
dawudshahidi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 6,890
