Salta al contenuto principale
The Rock Band Fender Stratocaster Wired Guitar is a guitar-shaped controller for the Rock Band video game franchise for Xbox 360.
2 Domande Visualizza tutte
Rock band 1 wired guitar will not turn on / connect.
I have a Xbox 360 wired Rockband 1 fender, it’s been 5ish years sense I last used it but I dug it out to play clone hero on, but when I plugged it wasn’t working, the light for the Xbox 360 logo on it would flash for a second and then shut off. I first tried a different break away cable end but I got the same result, I tried the classic wiggle the cable around to see if holding the cable in a specific way would make a better connection but I had no luck with that. I took the guitar apart and looked at the main board and there were these 2 capacitors that’s caps had turned a purplish black, all the other ones still had silver caps so I’m guessing that may be the problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
I have the exact same problem let me know if you solve it please and thank you
Punteggio 0
Did you fix it yet?
Punteggio 0
I have the exact same, but only the c52 is black. I'm gonna change it and tell you if that worked
Punteggio 0
Aggiungi la tua risposta
Sleepless Gamer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 33
Tutti i Tempi: 630
