2017 F-150 Transmission Fluid Check?
All the threads I have read so far say the transmission is not easily serviceable and has no dip stick...
Is there any DIY to check the fluid level and or change the fluid?
Questa è una buona domanda?
@rider883r that is correct. It uses a screw-in dipstick that you need to access from underneath the vehicle. Transmission Check
Thank you @oldturkey03, the pictures in your attachment look helpful. Will try to access it next time I am down there changing the engine oil.
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 116
Tutti i Tempi: 669
