Salta al contenuto principale
My PC is not starting.
My PC's SMPS (power supply) is working properly and cleaned RAM then also my PC is not starting. Green light is stable in PC, monitor is also in good condition.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
5 Risposte
Risposta Più Utile
1 or more of your RAM sticks might be dead
Try this trick: turn on your computer with 1 of your RAM sticks, if your display turns on that RAM stick works, if it doesn’t that RAM stick is dead repeat until all of your RAM sticks have been tested.
Punteggio 1
Testa o HD e depois o processador se tiver outros componentes para teste.
Retire a bateria da placa mãe e aguarde de 2 a 3 minutos e recoloque na placa, isso esse da as configurações da bios.
Punteggio 0
I on my PC but my PC in not on and red light show on start button
Punteggio 0
I on my PC but my PC is not on and show me red light on start button
Punteggio 0
amps not working power is not supply
Update (08/08/25)
smps not working power is not supply
Punteggio 0
Aggiungi la tua risposta
Uzaif Ali sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 501
