Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
Why does my keyboard from ifixit not fit?
I ordered a 2012-2015 MacBook Pro 15” keyboard from ifixit but it doesn’t fit my 2015 MacBook Pro 15”. There’s a notch below the spacebar on MacBook’s the upper case that doesn’t match up with the notch below the spacebar on the keyboard.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Good morning,
Last i checked, it isn't technically possible to replace the "keyboard" (the actual key mechanism) on it's own without pulling a Hugh Jeffreys. If your replacing the top case however, then that should work.
Can you add a photo showing the clearance issue as, from looking up on the internet, i can't find any obtrusive notch on the keyboard
Punteggio 0
1 Commento:
My bad, I’ve realized that the keyboard does fit. I’ve uploaded a photo as an answer. I thought the bit that juts out (circled in blue) goes around the the bit that’s circled in red.
da
Aggiungi la tua risposta
Owen Smith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 96
