Salta al contenuto principale
2.3L 4cyl or 3.0L V6, 6th Generation
What is code p1491
my honda accord has the check engine light the code is p 1491
Questa è una buona domanda?
Punteggio 0
1 Commento
Have the same code P1491 EGR car runs great been sitting with not much driving for 6 years No hard shifting and is quiet only 38,000 miles but traction control light comes on too off and on. ?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
alain soto, DTC P1491: EGR Valve Insufficient Lift Usually caused by a bad EGR valve, the solenoid, or the vacuum regulator. You may also remove the intake manifold and clean out the ports, there might be a lot of carbon buildup. Download great diagnostics instructions from here. Hope this helps, good luck
Punteggio 6
which solenoid?
Punteggio 0
1 Commento:
The EGR control solenoid which is inside the control box on the firewall
da
Aggiungi la tua risposta
alain soto sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 24
Tutti i Tempi: 42,021
