Salta al contenuto principale
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Restore to factory settings without my forgotten password
How do I force my ipad mini into factory settings when I can't remember password
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Hello! If you try to power the iPad on while holding the home button it should boot into recovery mode, then using a computer you can restore it to factory settings. If you have find my ipad enabled you may run into issues if you dont' have access to the icloud account its logged into anymore, as apple devices are tied to this ID when that is enabled, and you wont be able to use it again without that. @aklyman58
Punteggio 0
Plug the device into the computer, then press and hold the power button and the home button together at the same time. Once the tablet resets, let go of the power button while continuing to hold down the home button.
Punteggio 0
Aggiungi la tua risposta
Aklyman58 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 37
Tutti i Tempi: 278
