Salta al contenuto principale
LTV Series is a Ventilator manufactured by Pulmonetic Systems.
ventilator ltv 950 not working. power is on completed post test.
ventilator ltv 950 not working. power is on completed post test. but on vent check mode always. its not working normally. ventilator enters into vent check mode automatically on switching on.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Since this is a medical device, I think it will be hard to find information.
Based on your question, it is not getting feedback from the device that checks the vent and just hangs there. Similar to what Windows OS will do if it doesn't get feedback from a USB port.
Could be caused by a blockage. Any other cause is probably not user repairable.
Punteggio 0
you may have 2 situations, one can be select button is stuck and need to replace front panel, secondly check dip switch #5 to make sure it is off position (Switch toward outside ventilator). also #6&8 dip need to be off
Punteggio 0
Aggiungi la tua risposta
RAJ KOTTAK sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 78
