Salta al contenuto principale
The MSI GF65 Thin 10UE is a gaming laptop equipped with an Intel Core i7-10750H processor and NVIDIA GeForce RTX 3060 GPU. It is designed to handle gaming and demanding multitasking tasks. It comes with upgradable RAM and storage for future upgrades.
6 Domande Visualizza tutte
Screen gone blank, only a few vertical lines visible
I got this laptop repaired a few months ago. It was working fine, the repair changed pair of fans, thermal system and lcd. After a few months suddenly the screen got blank and only a few vertical lines are visible while turning it on, which eventually goes away. Can someone help fix it
Update (08/06/23)
Here is the attached image
Questa è una buona domanda?
Punteggio 0
1 Commento:
Here is the attached image [image|3040735]
da
Aggiungi un commento
1 Risposta
@abzo connect an external monitor to your laptop. If that displays fine, you know that your LCD is in need of replacement. If it shows the same, the issue could be related to your video circuitry (GPU etc.) and will require some inspection/rework of your motherboard.
Punteggio 0
Aggiungi la tua risposta
Abzo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 300
