Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
2 Commenti:
If you enable your phone hotspot while in the same room as the TV, does the TV detect that network? Do check your phone settings to make sure that the hotspot is not "hidden".
da Dany
Hi @alcporter,
Does it "see" other WiFi networks OK?
Have you checked that the router's WiFi is turned on if it isn't a dedicated WiFi only router but is a dual Ethernet/WiFi router?
da jayeff
