Salta al contenuto principale
A lawn mower is a machine utilizing one or more revolving blades to cut a grass surface to an even height. The height of the cut grass may be fixed by the design of the mower, but generally is adjustable by the operator, typically by a single master lever, or by a lever or nut and bolt on each of the machine's wheels.
My lawn mower won’t start on first pull and runs rough
i have a Honda Lawn Mower Hrr2169VKA. i had issues with it running so i decided to replace the Carburator, gas hoses, fuel shut off, the governor springs rods return linkage, fuel filter, all the gaskets on the card, spark plug, new gas 93 octane and 10-30 oil. it still runs rough and doesn’t like to start without carb cleaner in card to kick it on.
Questa è una buona domanda?
Punteggio 1
3 Commenti:
@scotttrainito can you check what engine your mower has. It could be a GCV160 A0 S3TE (GJAPA) but just want to make sure. Does your engine have a flywheel brake lever?
da
Honestly don’t know what engine. It does not have a blade brake….
da
@scotttrainito there should be a couple of weird numbers stamped into the engine block :-) That will be the engine number
da
Aggiungi un commento
1 Risposta
@scotttrainito sounds like you already have most of the common items replaced. your engines issue sounds like an ignition issue. I would check the ignition coil and set the air gap etc. to specs. Do a spark check and compression test. Clean the flywheel and coil as well. The only other thing I would do is to check the valves and set the valve clearance. Here is a quick manual for the Honda GCV145-170-200 which should essentially be the same as for your engine.
Repair Info GCV145 170 200GCV145 170 200
The SM is for the GC1600 which is a horizontal shaft engine. specs should essentially be the same. Honda GC160 GC190 GS190 Service Manual
Punteggio 0
8 Commenti:
Tyvm for the info
da
Ok it’s dark as hell out I can check tomorrow
da
@scotttrainito no problem Take your time. We'll be here. Can't cut the grass in the middle of the night anyway :-)
da
I just ordered an ignition coil. For 20.00 it can’t hurt to replace it.
da
I will set the air gap when it comes in using a business card.
da
Mostra altri 3 commenti
Aggiungi la tua risposta
Scott Trainito sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 639
