Salta al contenuto principale
Il primo dispositivo Nintendo 3DS è uscito a Febbraio 2011, identificato con il numero di modello CTR-001.
Nintendo 3DS Top Screen Not Visualizing Correctly?
Recently my Nintendo 3DS (out of warranty btw) popped out of its hinge. Being handy with small electronics I decided to open up the 3DS with help via a YouTube video and was able to get the hinge back in its place. Unfortunately, when I powered up my 3DS, I noticed there were lines across my handheld, the images were not centered, images magnified and everything had a negative effect. What happened here?
If anyone can help with tips that I can do, please send them my way, calling or sending it in to Nintendo isn't an option right now. Thanks for reading.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
4 Risposte
Soluzione Prescelta
The thin ribbon cable to your upper screen/LCD has been compromised. You need to replace the upper/top LCD. Click here, and select the Upper LCD Replacement guide to help you in this task.
Punteggio 2
"AB Cellars" was correct. I ended up replacing the LCD screen. A lot harder than an iPhone screen btw.
Punteggio 1
ey man I think I have the same problem but not sure, can I send you a picture of my screen so you can tell me if it the same please?
Punteggio 0
Have you fixed your problem? I think I have the same problem.
Punteggio 0
Aggiungi la tua risposta
Alexis Betancourt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,939
