Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Domande Visualizza tutte
Domanda Chiusa
iPod screen is popped up
I have had this 4th gen ipod for a while. Its in very good shape, but one day I was getting out of my car and it fell onto the concrete. On one side of the screen, the ipod pops up a little from the bottom side on the left which makes it so I can see white light from the inside whenever the ipod us unlocked. I have tried pushing it back down but it comes back up and i dont want to make it worse. The pics are below. I know it doesnt look like a big deal, but it bothers me and I dont want the crack to grow bigger. Any suggestions?
http://i1191.photobucket.com/albums/z472...
There is more of a thin white lining that goes halfway up the screen but it mainly starts from the bottom.
Questa è una buona domanda?
Punteggio 0
2 Commenti
I suspect you may have dented the metal casing. When it is dented the screen will not sit right. Had the screen been replaced previously?
da
Its never been replaced. My ipod has been perfectly fine. All i did was drop it and it came up like that ):
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Probably an issue with the adhesive or a dent. If you heat up the screen and remove it you might be able to replace the adhesive and fix it for a minimal cost, just be careful not to harm the LCD when you are removing it.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,416
