Salta al contenuto principale
he Xiaomi Redmi 8 is a low-budget smartphone by Xiaomi released October 2019. It has a 6.22" IPS LCD display, a 12 MP main camera, a rear-mounted fingerprint sensor, a 5000 mAh battery, and runs on a Snapdragon 439.
loud speaker isn't give clear sound?
i have redmi 8 smartphone whenever i play the music on high volume,the sound is very unpleasant to listen so please tell me how can i change my speaker so that i can fix it on my own.
Questa è una buona domanda?
Punteggio 6
4 Commenti
Battery exchange
da
I can not access my phone speaker
What should I do?????????
da
Suara speaker pecah dan tak karuan
da
Kalo hp tak sambung kabel charger mati hidupkalo sambung hidup normal padahal baterai 89%mohon petunjuk
da
Aggiungi un commento
5 Risposte
Risposta Più Utile
Suaranya tidak bisa
Punteggio 1
Spaker clene
Punteggio 1
when you put too much volume to your phone it will create distorted signal as it goes pass to the limit audio level that’s why it does sounds awful try to lower it down if the make it clear then there are no issue with your speaker if it stays the same distorted sounds well that has to be changed but it need a bit of experience to change the loud speaker as it involves a lot of tiny components insides which doesn’t need to be disturb or damage as you could create another issues instead of fixing it…. bring to the professional repair phone store for a proper diagnose and for peace of mind let them fix your phone instead
Punteggio 0
Speaker is another type of sound just like disturbing 😔 every one
Punteggio 0
My +
volume button is not working
Punteggio 0
Aggiungi la tua risposta
Sumit Sharma sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 73
Tutti i Tempi: 1,213
