Salta al contenuto principale
Repair guides, support, and troubleshooting information for MacBook Air models with 15-inch displays.
I have a problem with the TouchPad
Hi, I’m Vivek Chaudhary from Rewari
I have a 15” MacBook Air with problems with TouchPad
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
This system should still be covered under Apple warranty as it was just released. Are you sure you picked the correct system? To be sure plug in your systems S/N here EveryMac - Lookup see what it tells you, the newer models won’t report correctly, even still let us know.
As to your problem, did you have a liquid spill (or get it wet) or damage the system in someway?
Punteggio 0
you should get the trackpad replaced i believe,thats what it is most likely like 99% chance that its that
Punteggio 0
Aggiungi la tua risposta
Vivek Chaudhary sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 170
