What kind of screws?
Does anyone know what kind if screws the PAL uses? I stripped them opening it up and want to replace.
Questa è una buona domanda?
They are most likely metric. Ace Hardware usually carries an assortment of metric screws. Take it in and see if you can find the right one.
@julianboilen those look like #6 or #8 x3/4 rolling screws for plastics. You could measure the diameter and length with a pair of calipers or similar. #6 is 9/64" and #8 is 5/32" in diameter. Do not use wood screws from a hardware store since those are different. I am sure that the needed screws are readily available online.
Hi, did you find out which screw you needed for the Tivolio Ipal radio ? I am looking to get screws as I have misplaced those that hold in the back plate for the battery compartment.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 73
