What to do if Display Touch is not working of Samsung galaxy A50s
What to do if our Samsung galaxy A50 s mobile display touch is not working
Questa è una buona domanda?
some troubleshooting questions to ask to hopefully narrow this down. and either I or someone else can give you the answer.
there are tons of other questions to ask. but these sets are a good place to get started.
as stated earlier I don’t like to fill in the info myself for these questions as that leads to poor troubleshooting and won’t help you.
@pawanbaheti I would always do a soft reset first. Just to make sure that it is not a software issue. Press and hold the Power button and Volume down button, down simultaneously for more than 7 seconds. You will feel it vibrate when your phone restarts.
I that did not resolve anything it could be time to replace the digitizer, which is part of the display assembly. To replace the LCD use something like this video
If even with a new display your touchscreen still does not work, your phone may need a board level check. SOmething like this flowchart will help with that.
To find the components to check use your search function on your PDF reader to locate them from this Component Layout
Fingerprints not working
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 49
Tutti i Tempi: 488
nature problem
da androad
