Salta al contenuto principale
Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
Anyone know where this chip goes?
Hello Forum,
I went into clean my fans and I found this chip floating around inside my mac!!
Had a look on the front and rear of logic board and compared it to the diagrams, but I can't seem to find where the little bugger goes, Does anybody know?
front of logic board
Rear/underside
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@graintocask that actually looks like a microphone, Apple part number 821-03594-A. Check your flex cable and see if it has come off.
Punteggio 4
5 Commenti:
@oldturkey03 - I too thought the same thing, but it doesn’t match up if you look at the MacBook Pro 14" (A2442, A2779, A2918, A2992) Microphone unless Apple modified this series to a different design.
da
@danj yes you are right. probably another mod they did not tell anybody about. I am certain that if @graintocask takes a look at it, one of the mics will be missing.
@graintocask the part should be identifiable by the markings on it. Post another picture, but this time zoom into it, so we can make out what it says.
da
@oldturkey03 -Yup it's from that the serial numbers on the chips match up from an image I found to the rogue one.
Stupid question but whats it for? My mic is still working (at least on whatsapp) find it hard to believe this part is superfluous.
Thanks for your help
da
@graintocask that is because your MBP actually uses three mics for the same thing. I am not going to call it a spare, but your other ones are most likely "taking up the slack" for the missing one.
da
@graintocask The microphone flex cable makes use of multiple microphones. So depending on function of the missing one, you may not even notice.
da
Aggiungi la tua risposta
Grain To Cask sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 27
Tutti i Tempi: 242
