Salta al contenuto principale
This iteration of Amazon's Kindle Paperwhite series was released on June 30, 2015. The Kindle Paperwhite 3rd Generation is a 6-inch, 300 PPI reading display tablet that is Wi-Fi capable. The designated model number is DP75SDI.
20 Domande Visualizza tutte
Kindle Paperwhite stuck on boot (kindle tree logo)
For some context. I just got gifted this kindle so if I can fix it it's mine and I need an upgrade from my 4th gen non-touch kindle.
I've tried the holding the button method for a reset. The screen flickers black then white again and it's stuck on the screen again.
I tried plugging it in my macbook but it doesn't show up even during resetting
Any ideas on how to fix that?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hey there!
I'm sorry to hear that you kindle is not working. Let's see if we can fix that! Try following this guide to disconnect and remove the kindle's battery. Now, just for clarity, the kindle won't power down when you hold the power button? Also, is there a loading bar on the screen? If the answer to the first question is yes, then you'll need to be very carefull while inside so you don't short the kindle or yourself out. Once you have the battery disconnected, leave the kindle alone for a little while and let all the power drain. You can help it along by pushing the power button. Once you are sure it has fully drained, reconnect the battery and try turning it back on. There is no need to reassemble the device, just don't touch any of the circuitry inside while it is on. Hopefully, the hard reset (as what you just did is called) did the trick and there will be no need for further troublshooting. If that is the case, please accept my answer so that others can see that the answer helped you. If it didn't work, just post a comment here and we'll get it worked out!
Good luck!
Punteggio 1
Did you try this and did following this guide fix your kindle? I have the same problem. My kindle is stuck on the kindle tree logo. If I drain the battery then plug the power back in then the battery icon appears with 1 bar but after charging for 10 minutes or so the kindle tree logo screen returns and I am back to square one. No amount of hard resetting fixes it.
. Will replacing the battery force the kindle to function properly? (It's a Paperwhite 3 2015, but says 7th gen!?)
Punteggio 0
Aggiungi la tua risposta
Unadvised Deonisii sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,293
