How to reattach the globe?
What is the trick to reattach the globe? I align the 4 screw into the slots on the base but nothing locks the globe to the base. Any suggestions?
Questa è una buona domanda?
Have you tried turning the globe? There's usually only two possible methods of locking. Either align and then turn or align and then tighten!
Yep. there are 4 screws that fit into slots on the yellow base. Once the screw heads are in the slots, it doesn't turn and doesn't lock
My next question would be are you sure you've used the correct screws, next is it possible to set the globe on them install the screws. If you could post some pictures of the slots in the globe and of the four screws your talking about?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 64
