Salta al contenuto principale
A1708 / EMC 3164 — Lanciato a giugno 2017, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED.
Keyboard and trackpad is unresponsive
Keyboard and trackpad became unresponsive suddenly. Power button works. No response from keyboard or trackpad on login-screen. Using cabled keyboard and mouse works for login and working on the Mac. The onboard keyboard and trackpad is also not working after login. There have been no spills, drops or any other events before the malfunction.
I have tried to update to newest MacOS without any change to the problem.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
If you're getting response on external keyboard, I would try an NVRAM reset. You may even be able to use the internal keyboard to do this.
Otherwise, my money is on the trackpad, or the trackpad cable being bad. The trackpad often contains components that are for more than just the trackpad, keyboard functions also typically route some communications through the trackpad.
Punteggio 1
Aggiungi la tua risposta
Martin Groth Jensen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 100
