Salta al contenuto principale
Modelli A1419 / Fine 2012 / Processori 2.9 & 3.2 GHz Core i5 o 3.4 GHz Core i7, ID iMac13,2
Why is my mac so slow?
Booting up takes 3 Minutes and opening a program like word or mail takes over 1 minute.
Questa è una buona domanda?
Punteggio 0
7 Commenti
Have you considered reinstalling the OS and switching to an SSD for faster read/writing speed?
da
@dinoo_fixit - That’s a strong possibility but not the first thing I would do.
da
@danj Right, but maybe after fixing this issue, replacing the ten years old 7200 rpm HDD with an SSD and increasing the RAM wouldn't be a bad idea
da
@dinoo_fixit - I don’t disagree! The core issue is likely something else.
da
@danj You're right
da
Mostra altri 2 commenti
Aggiungi un commento
1 Risposta
Risposta Più Utile
I would run the onboard diagnostics to see if something is not working correctly. Your system will go into CPU Safe mode which reduces the systems CPU clocking to a crawl!
To get to diags restart your system and press the D key on your keyboard at startup. Here’s a good reference Mac startup key combinations
Let us know what you got for an error/s
Punteggio 2
2 Commenti:
Cannot Load EFI/Drivers/TestSupport.efi
This is the error message I get
da
@maximmotyka - That sucks! Thank you Apple! 😖🤬😖🤬
Did you try the online version as well? I hate winging it! Let’s assume the drive is just badly fragmented, then defragging the drive would be what I would do. But before you do that make sure you have a good backup!
I would get this product as I find it’s one of the better ones! Drive Genius it’s what I use.
da
Aggiungi la tua risposta
Maxim Motyka sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 191
