Salta al contenuto principale
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
My controller won't turn on.
I recently built a controller but it won't turn on. I'm new to soldering and feel like that may be the problem but nothing looks burnt up. I did feel a little warmth trying to turn the controller on, but I assumed that it might be leftover heat from the solder.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi I’m new to soldering to. Congrats on attempting a repair.
If nothing looks burnt I would check to make sure something isn’t bridged. A bridge would be when two points are touching each other. I’m not sure where you were soldering but that is what I would start with
Punteggio 1
1 Commento:
Thank you, I'll look for a bridge. I just found out that the main board is working because I can hear the buzzing sound coming from it, but the light is not turning on.
da
Aggiungi la tua risposta
PonySoldier sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 210
