Hi Conny,
Let me 'fess up that I'm not an expert on cellular antennas by any means, but I see that your description of what's going on with your phone seems to match up with the solution description for what the French site SOSav calls the External Speaker & GSM Antenna.
External speaker & GSM antenna iPhone SE (2nd Generation) repair - Free guide - SOSav
Here's their description from the guide.
Does your iPhone SE 2020 no longer make any sound? Does the sound mute when you watch a video? Doesn't it ring anymore? The sound remains weak while the volume is at maximum? And yet everything works when you call? This is because it is a separate speaker! In your case, the iPhone SE 2020 external speaker is faulty. It manages all the sound of the iPhone except calls. Also on this speaker is the GSM antenna . So if you have problems receiving 3G / 4G network, this is also the part that you should change. The experts at SOSav are there to support you throughout the maneuver through this illustrated repair guide and each step is detailed in detail to prove to you that repairing your iPhone SE 2020 is possible and economical.
That would be my first pass at fixing this problem, to replace that antenna. It's actually glued to the speaker, but is sold separately. The iPhone 8 and the SE 2020 use the same parts for both, so finding an antenna for either will work. Here's an example that came up on a cursory search; I usually start by checking eBay, Amazon and AliExpress, depending on my desired cost vs. shipping time tradeoffs.
Loud Speaker Antenna Flex Cable For Apple iPhone 8 / iPhone SE (2020) 657472789805
Don't forget to pick up a sheet of precut adhesive for sealing the display back up against water when you're done! Personally I usually buy a couple because they're easy to mess up and if they don't go on right the first time, you usually can't recover them and just end up with a tangled ball of glue. So having an extra on hand means you won't have to wait to finish your phone until you can reorder.
Good luck; let us know how it goes!
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
