Salta al contenuto principale
La Passat B6 venne presentata per la prima volta al Geneva Motor Show a marzo 2005 e lanciata in Europa nell'estate del 2005.
20 Domande Visualizza tutte
The Engine light is always turned on
My engine light is always turned on despite there is no issues with the engine, so how do I turn it off
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@pawanrai the engine light can be on for a multitude of reasons. I suggest you get the OBD2 scanned and see if and what code it shows. You can also reset the OBD2 with the scan tool.
If you know for sure that there are no issues with it, you can reset the light by removing the NEGATIVE battery cable. Remove it and keep it off for a few minutes. Then reconnect.
Punteggio 2
Aggiungi la tua risposta
Pawan Rai sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 95
