Salta al contenuto principale
Model A1288 / 8, 16, or 32 GB capacity
451 Domande Visualizza tutte
Restore wont take hold
I have an ipod that I've restored three times now and when re-booted will go back to the restore screen again. I've restored using itunes in both normal mode and by putting it into DFU. I don't know the history of the ipod but it does have the moisture indicator red.
I've also used iReb to see if I can get it out of the restore loop and that didn't help either. Is this Ipod a lost cause? Should I keep restoring it? Should I try an earlier firmware than the latest? Any other suggestions?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Did you try the fix recovery option in redsn0w?
Punteggio 2
3 Commenti:
Good idea, but didn't work.
With your idea I did try the latest redsnow but it doesn't support autodetect on the 2g so I couldn't use it. This led me to try tiny umbrella recovery and it didn't fix problem either.
da
Hmm... Maybe try a custom firmware? or a older redsn0w?
da
I found an older firmware which seemed to work. I put it on and ipod booted to main screen and I was able to put some songs and apps on it. Unfortunately, even though I was able to boot a few times immediately after that, when I booted the next day it went into recovery mode again.
da
make my ipod disabled unlock
Punteggio 0
Aggiungi la tua risposta
Carpenter940 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 11
Tutti i Tempi: 437
