Salta al contenuto principale
Il telefono più popolare di Apple del 2021 è stato lanciato sul mercato il 24 settembre e ha uno schermo OLED da 6,1", un sistema di fotocamera doppia da 12 MP ed è disponibile in cinque diversi colori. È il successore dell'iPhone 12.
Side buttons do not work
Hello all,
Yesterday, I was trying to swap the back housing of my iPhone 13. While doing that, when I was removing the buttons (Power, volume buttons connector) connector from the board, I have a feeling that my plastic repair tool (the one people use to disconnect the cable) perhaps damaged/scratched the connector. Anyway, after putting it all back together, none of my side buttons worked. I had an extra button cable and that one, the power button on the right side worked, but still no luck for the left side where the mute and volume buttons are located.
Does it mean I may have damaged the cable connector on the board where I plug the connector in? If so, how can I replace it? This seems like replacing the entire board?
Can someone help me how to troubleshoot this? Thank you
Questa è una buona domanda?
Punteggio 0
1 Commento
Hello, some photos will help to identify the problem. When is the connector on board damaged, dont must replace complete board, only the connector. But for this need hot air soldering.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
You need a microscope or a loupe to examine the pins on the connector itself. If you damaged it you'll have to find somewhere that does micro soldering unless you can do it yourself. Also check you haven't knocked off any components from around the connector itself.
Punteggio 1
Aggiungi la tua risposta
JC1213 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 504
