Salta al contenuto principale
Seems to be charged but will not start
on docking Station charged, I press clean using remote it lights up the three lights blue solid X 2 front either side of start button front of machine ,then after about a minuite lights go out showing only one blue either side then after about a minuite and half switches off not even activate clear of any possible snags .clear of any over closed filters or debri
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@privateproperty all of this sounds like a battery issue. If nothing else, I would replace it so that you know you have a know good place for further troubleshooting. Remember that the battery may charge but may not hold a charge for long and fail under power consumption. Use something like this video to work on your robot.
While you work on your robot, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Punteggio 0
Aggiungi la tua risposta
Private Property sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 36
Tutti i Tempi: 1,418
