Salta al contenuto principale
The HTC Aria s a smartphone manufactured by HTC Corporation.
2 Domande Visualizza tutte
How do I fix my touch screen?
My touch screen just stopped working. It doesn't sense me touching it with my finger. If i press hard it'll barely sense it. I can't even unlock my phone!
Questa è una buona domanda?
Punteggio 8
2 Commenti
guys i have a huawei ascend and my heat sensor doesnt work please help how do i fix it
da
Guy good mor/after/eve please help me my right middle screen is not functioning help me please#NEEDHELP
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Don, try a hard reset by following the steps from here first"
1. Turn the power off. If your HTC Aria is frozen, pull the battery out and reinsert it
2. Hold the Volume Down button
3. Hold the Power button until the display turns on
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button to select
7. Confirm: Volume Up for YES and Volume Down for NO"
This will delete all the data from the phone, but not from the memory card.
If that does not help, you might be due for a digitizer replacement. The video instructions are available here and you can get the digitizer from places like this. Hope this helps, good luck.
Punteggio 5
4 Commenti:
I have a HTC Legend. I tried your solution, I didn't know about the hidden menu. Mine didn't start after clearing storage. So I accessed the Fastbook menu and there I tried the second or the third submenu, I don't remember accurately. Thanx for the help!
da
memoriesfromthefuture, you are welcome. Glad I could help out, best of luck to you.
da
Just had my little htc aria unlocked at http://www.attphoneunlockingshop.us/ Thanks !!!. this is the only site i use to unlock lumias.
Go to this link and place the order: http://www.attphoneunlockingshop.us/prod...
Video: https://www.youtube.com/watch?v=JsbjkX8p...
da
Just had my little HTC Aria unlocked at http://www.attphoneunlockingshop.us/ Thanks !!!. this is the only site i use to unlock HTC Aria
Go to this link and place the order: https://www.youtube.com/watch?v=JsbjkX8p...
da
contact to nearest cell phone repair store to change lcd panel. if you believe it is OS issue so you can contact to http://attunlockcodes.com team for help.
thanks
Punteggio 0
1 Commento:
Network unlock codes
da
Aggiungi la tua risposta
Don sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 44,661
