Salta al contenuto principale
Annunciato il 13 ottobre, l'iPhone 12 Mini è una versione più piccola dell'iPhone 12 di Apple. Si caratterizza per lo schermo OLED da 5,4", processore A14 bionic e per la doppia fotocamera posteriore
Screen replacement - iPhone 12 MINI with OLED display
My screen is not working. I wanted to buy the replacement from ifixit. But you only have the LCD in stock. IF I change it with LCD, will it work?
I just want to be able to turn on my iCloud on the device so data can be recovered. Right now I cant do anything as the screen is not working.
If I get the LCD, will it temporarily work? As i said, I only need to screen to work for a short term so I can start the backup.
What other screen can i use to replace my current one? What are my options. Buying OLED would be too expensive. Please let me know if you have any suggestions
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
this isnt the actual store and only a help forum, yes an lcd will work and will function as normal, the only difference is you wont have truetone, you will have a warning that the screen might not be genuine and the battery will be used slightly more with an lcd
Punteggio 1
If it's just to get your data then buy a cheap screen. Hook it up and get your data off it. Don't see the point in spending hundreds just to get data.
Punteggio 1
Aggiungi la tua risposta
ROK sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 390
