How to replace memory
i need to remove the hard drive
Questa è una buona domanda?
While the SSD drive is removable as you can see here in Step 11 in this teardown which is exactly the same as your system Smontaggio MacBook Pro 13" Function Keys versione fine 2016 it uses a custom interface, so unless you have a second function key system to plug it into you can’t access the data within it.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 84
