Salta al contenuto principale
Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
Charger and power indicator.
My laptop is critical low battery. When I plug in the charger the charging indicator will blink 3× times then power indicator which is blue blink and then they blink at the same time. What is the possible problem and the solution. Thanks for the answer.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
I have the same issue in the laptop. Mine is because I've used the charging port badly. It will probably need a change of the port.
Also, my fans turn up and down without any reason, and doesn't for a while when a game is being played- get's heated until I turn fans to max in NitroSense.
I don't know if that's related to the charging issue though.
Punteggio 0
Aggiungi la tua risposta
MASHEEET sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 102
