Salta al contenuto principale
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
Not using battery power just outlet power
On my mid-2012 MacBook Air I have to plug it into the outlet to make it come on. It won’t use the battery that is inside of it. I replace the battery but still not using it also I have tried to do a SMC reset but that didn’t work either.
Update (05/30/23)
This is not reading the battery and it’s new.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Let’s get a better view of things install this gem of an App CoconutBattery Take a snapshot and post it here for us to see.
Punteggio 0
7 Commenti:
I have that already and when I click it on it. It doesn’t show how much count cycles it has and I tried to get the battery icon to show up on the menu bar but it doesn’t want to show it at all.
da
@jordanchapman - Can you post a snapshot of CoconutBattery so we can see things.
da
@jordanchapman - Bingo! This is a bad battery. The micro-controller within the battery is bad. You’ll need a replacement battery from the store you got the battery from if it’s new otherwise it’s time for a new battery.
da
Ok I just put a new battery into from my friends computer and still shows the same thing. Also it still doesn’t come on when the battery is plugged in.
da
@jordanchapman - Did you damage the battery’s cable/connector? The data connection from the battery is not getting through to SMC logic.
Did this system have a liquid spill? As corrosion damage can also damage the copper traces on the logic board. Time to take the logic board fully out and do a deep inspection. Look at the back side of the keyboard area for staining, look for discoloration and damaged components on the back side of the logic board. Did you use a metal tool to get the battery connector disconnected? That could have shorted out the data lines on the logic board.
Nine out of ten times this is a bad battery!
da
Mostra altri 2 commenti
Aggiungi la tua risposta
Jordan Chapman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 121
