My oil cap pops off where is the pressure comming from?
Where and what could be the cause
Questa è una buona domanda?
If the cap gets blown off, there is too much pressure in the crankcase. Blow-by can be caused by piston rings that are worn out. A cylinder with worn out rings will have low compression and will likely cause a misfire. These piston rings need to be replaced.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 26
how many miles are on the truck? What engine do you have?
da Jesse Hooton
