Salta al contenuto principale
2.26 or 2.4 GHz / White plastic unibody enclosure
Why does my MacBook’s screen is half dim?
I have a a1342 MacBook with almost entire half right part of the screen dimmer than the other.
It also has the spotlights phenomena while the left half doesn’t have it at all.
I tried to replace the display data cable but no luck, what else can I try?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
MY GUESS, Is the Backlight on the right side of the display Broke.
If it's a problem to you, It should be replaced
Part: MacBook Pro 13" Unibody LCD Panel
Guide: MacBook Unibody Model A1342 LCD Replacement
Immagine Replace a glossy or anti-glare display panel compatible with the A1278 Late 2008, A1342 Late 2009 to Mid 2010 MacBook 13" Unibody models and A1278 MacBook Pro 13" Unibody model laptop. 1280 x 800 pixel Resolution. 13.3".
Prodotto
$69.99
Punteggio 0
Aggiungi la tua risposta
lotem sayag sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 118
