Salta al contenuto principale
The Honda Fit, also marketed as the Honda Jazz, is a five-door, front-engine, front-wheel drive B-segment subcompact car manufactured and marketed by Honda since 2001 and now in its third generation. Marketed worldwide and manufactured at ten plants in eight countries, sales reached almost 5 million by mid-2013.
20 Domande Visualizza tutte
Why does my heating shield make noise
It makes a rattle noise from heating shield , every time I accelerate car
Questa è una buona domanda?
Punteggio 0
1 Commento:
Be more specific, what Fit what specs what noise.
da
Aggiungi un commento
1 Risposta
One or more fasteners are loose or missing. Another possibility is the heat shield is bent reducing the clearance require to prevent a rattle. this should be a quick and easy repair that will cost you less than $100. A third possibility is a broken exhaust hanger that allows the exhaust system to move far enough to contact the heat shield. One more possibility is a broken or wore out engine mount. If engine movement is excessive that may allow the exhaust to contact the heat shield.
Punteggio 0
Aggiungi la tua risposta
LiL Ivan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 147
