Salta al contenuto principale
The Jeep Cherokee is a line of vehicles sold by Jeep under various vehicle classes. Originally sold as a variant of the popular Jeep Wagoneer, the Cherokee has evolved from a full-size SUV to one of the first compact SUVs and eventually into its current incarnation as a crossover SUV.
20 Domande Visualizza tutte
Jeep Cherokee 87 won't start
1987 Jeep Cherokee Limited four-wheel drive won't start turns over gets fuel has new coil parked it after work went out in the morning wouldn't start ran day before
Questa è una buona domanda?
Punteggio 1
1 Commento
@rutor1 did you check for spark on all cylinders? What else did you check?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Rutor,
This almost certainly has to do with your coil or coil wires just based on your description of it happening after a rainfall. Since you just replaced the coil, let’s assume that is good. So, I’d suggest buying a new set of plug wires and the wire that goes from the coil to the distributor (if it is separate…sorry i don’t know this engine by heart). Or, the wire that feeds the coil (12VDC) might be shorting out. Best of luck.
Punteggio 1
Aggiungi la tua risposta
Rutor1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 72
