Why is my F150 not getting enough power to move after replacing the ma
Diagnostics stated the manifold needed replacing. It is still not getting enough power to drive or move after a new manifold was installed.
Questa è una buona domanda?
A MANIFOLD????
There is an EXHAUST and an INTAKE manifold. They are purely mechanical. I have never seen a diagnosis of a bad manifold.
Therefore, replacing one wouldn't solve any problems unless it was physically broken.
So, your problem needs more diagnosis. A problem like that should set a code. Unless maybe your parking brake is set.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 29
If there was an error code, post it. On the chance that you misunderstood the error as a manifold fault, is this the manifold absolute pressure (MAP) sensor error, P0105?
da F Dryer
