Salta al contenuto principale
The Oculus Quest is the first standalone virtual reality headset that supports 6DOF tracking with cameras located on the headset itself. The Oculus Quest headset was released in May 2019 in 64 GB and 128 GB models.
Can I replace the charging port?
The charging port on my headset is broken and i was wondering if i could replace it somehow on my own
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
You might be able to. Or at least replace the cable the charge port is on. I found a fairly thorough teardown of the device and it looks to me like the charge port is part of a flex cable which also carries signals from whatever other minor boards or components are on that side of the headset to the main board.
It looks like a bit of work, but doable if you can find a replacement part.
Punteggio 1
Aggiungi la tua risposta
Blake T Francis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 594
