Transmission stuck in 4x4 low
My 1997 Sport Trac is stuck in 4x4low
Questa è una buona domanda?
If you can't get out of 4low, disconnect the batty for the car and wait about 5 minutes, then try shifting out of 4 low (Make sure you're on N)
And if that does not work, try pressing the 4high button and shift into reverse, neutral, drive, neutral, and reverse. If you do this about 5 to 10 times it should catch on and get out of 4 low
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 65
@michaeldaigle AT I assume. What have you tried? What happened that it got stuck? Anything unusual?
da oldturkey03
