Salta al contenuto principale
Repair and maintenance guide for Bosch 11321EVS, a demolition drill made by Bosch, model number: 11321EVS.
Seems to not be getting power
Green light on side of hammer goes on and off when I wiggle the cord. Cord has no visible damage and each wire in the cord has continuity. The wire connection block for the ground (green wire) seems to wiggle. The brushes on the motor appear to be only 1/2 worn.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
could still be an issue with the cable as you said the light blinks when you wiggle it. cut about 5 inches off the top and rewire it. i have repaired 2 titan sds breakers and the cable was the issue on both
Punteggio 2
Aggiungi la tua risposta
Ranford Johnson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 36
Tutti i Tempi: 314
