What is the correct fuse?
What is the correct fuse to replace the old, that is burned.
Thanks
Questa è una buona domanda?
Thanks
If you changed the fuse three times and it burns out, you have a short circuit and/or overload in your system. The fuse is doing its job by protecting your circuits.
Look at the fuse side you will see how much the Amp on it and should the volt will be 110v-120v
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 819
2 Commenti
What is the speed of your machine so I know which one you have?
da mayer
I change the fuse, in 3 times it burned, in other time nothing happening...
da Renan Andrade
