Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Poor Service/Wifi after changing digitizer
So I replaced the digitizer on my phone and ever since the wifi signal has been absolutely poor. Does anybody know what may cause this or if I might of messed up a part doing it.
Questa è una buona domanda?
Punteggio 1
1 Commento
What if that little part on the backside of the cover is missing. Can you buy a new, or do something Else, to fix it?
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You have done one of two things wrong. Either you have had this tiny part fall off and you did not know where to put it.
It goes here
Or you did not use the correct length screw in this hole. The longest screw within the iPhone goes here.
Also the oil from your fingers can affect Wi-Fi signal strength. So clean all contact points with Isopropyl alcohol.
Revision
To show you which screw is in fact correct I have edited an image of the whole set of screws within an iPhone 4.
Complete original set of screws.
Shown here is the screw that I originally said was the correct screw. In fact I was wrong.
Here is the actual screw required. Please note that it has a smaller head diameter.
Punteggio 5
2 Commenti:
great answer with pics too?? absolutely a "+"!
da
Thanks for the help man!
da
Where does that squiggley black piece go?
Punteggio 0
It goes on top, above the battery, near the camera:
Punteggio 0
Aggiungi la tua risposta
Arron Mayers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,261
