Salta al contenuto principale
Lanciato il 26 ottobre 2018. Modelli A1984, A2105, A2106, A2108. Disponibile in versioni GSM o CDMA / eSIM, nano-SIM o dual-SIM / 64, 128 o 256 GB / Bianco, Nero, Blu, Giallo, Corallo o Rosso.
iPhone Xr front facing camera not working after screen replacement
The front facing camera on my iPhone XR doesn't want to activate anymore after a screen replacement and it was just that
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Unfortunately No I fixed it myself for a family friend I even used the original parts for the phone like the earpiece speaker and put it back into place I've checked everything and nothing appears to be broken or ripped also what peice of film do you mean because when I opened the phone I didn't find one just the usual cables connected together.
Punteggio 0
1 Commento:
Check you haven’t dislodged the camera connector by accident when you’ve removed the screen. It’s easy to catch other connectors if you’re unsure what your doing. Disconnect and reconnect the connectors making they click into place correctly then try it.
da
Hi Henry,
That's an odd one, since the normal procedure for replacing a screen doesn't involve the front camera at all. Is this a screen replacement you did yourself, or did you have a shop do it?
If it was a shop, you would need to take it back to them and tell them they need to fix whatever they messed up.
Otherwise you'll probably need to open the phone back up and check the front camera. I've seen a couple of cases where there was a piece of film over the camera opening that was meant to protect the glass but needed to be removed before assembling the phone and wasn't.
That's the most likely cause, but if that's not it, you'll probably have to check the flex cable for the front camera and make sure it didn't get damaged durning the screen replacement. Unplug it and check the connector on both the logic board and the flex cable. Clean them with 90% or higher concentration of isopropyl alcohol, then reconnect the camera, making sure it's plugged in fully and firmly.
Check that camera opening for any obstruction and if that's not it, check the camera connection and let us know what you find.
Punteggio 0
Aggiungi la tua risposta
Henry Teyuca sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,027
